I am working on a steam locomotive project, it's a modified Bachmann "connie" 2-8-0. I have decided that I am going to go with North Coast Engineering DCC as the control system for my railroad, and this locomotive is going to be the first of my locomotives to be converted to DCC.
I have gutted all the stock electronics from the locomotive, and im not planning to put anything back in..
Im ready to put the locomotive back together..here she is now(ish):
Its still going to be awhile before I start buying DCC equipment..I have the power supply, and because of the cost I will probably buy the DCC system in pieces, (booster, command station, and cab), and sound system! so its going to be another year before I have it all..
meanwhile, im ready to "finish" the locomotive..put all the details back on, and paint it, then it will be complete except for its electronics..
Im going to put everything in the tender..DCC decoder, speaker, and sound system. (Its going to be using a Bachmann big hauler tender)..
So, my question..what are some good connectors to use between the locomotive and the tender? I found a DCC wiring diagram for reference:
My locomotive will have three pairs of wires between the locomotive and the tender..six wires total:
1. two wires from the headlight.
2. two wires from the drivers (track power pickup)
3. and two wires connected directly to the motor.
The wires will run through the boiler, and terminate in connectors under the cab, which will then be plugged into the tender..
Connectors could be three sets of two pin connectors.
Two sets of three pin connectors..
perhaps even one 6-pin connector! if such a thing exists..
anyone have any suggestions?
thanks,
Scot
thanks,
Scot
