I am building a layout that includes one reverse loop and one wye. I plan to use two 55085 modules to make this work.
Several questions:
1. How would you wire up the wye on my layout? Please refer to the attached layout diagram. I have added the letters “A”, “B”, “C”, “D” and "E" so you can clearly explain where I would create the isolated track section(s) and install the reverse loop wiring/components. Do I need another isolated track section (let's call it "F") just to the left of "D" and before "E".
2. Related to #1 above, do I need to create isolated track sections that are connected to a reverse loop module on each side of the wye to enable full reverse loop functionality?
3. Will my trains be able to run through the Wye in either direction if I only create one isolated track section on the wye and wire it up to the reverse loop module?
Thank you for your assistance.
Several questions:
