.....Stainz? (well, besides me)
A fellow in Canada was nice enough to sell me a plow that he thought was made to fit the LGB Mogul, for $20. I was still procrastina... err thinking on how I was going to do the Climax roof this afternoon when the box arrived. -- Distractions and tangents are always more interesting than what you should be doing anyway
I don't HAVE a mogul anymore, it was rather too big for my layout and I needed the cash, but I DO have the much loved (abused?) 2017D that I got off Stan Cedarleaf and Americanized even more. It was here - and let's just say I'm not a real big fan of "Wild West" wooden cow catchers anyway...
First I removed the pilot from the Stainz. It isn't hard, you just unscrew the smokestack, pull it upwards about an inch, then pull the pilot out. I cut the mount off just behind the beam, then had another idea and wished I hadn't. I also mis-measured and cut the snowplow bracket off a smidge short as well... 2 goobers in less than 10 minutes!.... Anyway, I used a dremel to mill pilot beam reliefs in the plow itself, then used basswood to make a new beam, and I cut a piece of balsa to fit in the gap against the cylinder saddle, so it's not obvious unless you look real close that I screwed up....
The plow, as seen from underneath, featuring my 'jerry rigged' mounts
90 minutes from start to finish and it was on the Stainz, it needs a few bits and some weathering to blend it in better. I decided that, since on my present layout it is always June, the shiny bare metal look was out of place. The face of the plow is Raw Umber, I think it's a pretty fair match for old rust, the back and brackets are SC Black to try to match the weathered black on the 2017 (I need to go a bit darker). Will it actually plow? The 2017 is heavy, has 2 motors, 10 pick ups, and 8 wheel drive.... the only question is if the tab on the mounting bracket would stand the strain.
