What is DCC in Large Scale?
8188 Views 28 Replies 12 Participants Last post by  Mike O
Sometimes when you ask "What is DCC?" you get an answer that is outdated, and really applies to smaller indoor scales.
OLD ANSWERS:
  1. Gives you control over lights and sounds.
  2. Controls several locos at one time on one track.
  3. Provides constant lighting.
So, What does DCC mean to garden Railroaders?
1. Do we really control of all those lights and sounds?
Our locos are much bigger, so, for quite a while, we've had more features includeing: smoke, cab lights, marker lights, flickering firelights in the ash pan, mars lights, ditch lights, track lights, fuel tank lights.
 Just how many buttons do we need? How many can we remember?
Fortunately, DCC decoders are really tiny computers, already programed to do all sorts of stuff for us. We just need to select the features we want. That is done by setting up the decoder configuration using CV's (Configuration Variables).
Here are a couple examples:
Our sound decoder plays a crossing signal when we press button "F4" on our hand held remote. If running a modern diesel, we need to turn on the mars lights, and or alternately flash the ditch lights. we can program the motor decoder to do that for us automatically.
We turn on the bell in our sound decoder with F2. That is required when running in a yard doing switching operations. We can also configure the motor decoder to dim the headlight and backup light, which is also required for operation in yard limits, At the same time, we could configure the motor decoder to change the speed range for slower operation with much finer control and reduce the momentum effects so we can stop and start a little quicker. All that with just one button.
The simple truth is, DCC is not so much about instant control as it is about preprgramed control.  Control that is smarter and eaiser, with fewer buttons, yet more realistic.
Block wiring does that, and so does radio control. So What does DCC do for us.
First, DCC eliminates all wiring except for two wires going to the track. Anyone who has had to deal with buried wires in the garden can appreciate that. We can operate all our turnout, signals, turntables, locos, and the lights and sounds in our  passenger cars and cabooses from the data on those two wires.
Second, It eliminates the glitching and range problems of radio control. A DCC wireless throttle communicates with one or more fixed receivers. Located permanently the receivers provide full coverage. You are never out of range of any loco even one in a steel lined tunnel. You can control any loco, the lights and sounds in any car, or any turnout, signal or stationary device from your remote. You can use any remote to control any train, You can even have two different remotes controlling the same train for buddy operation with a new visitor. Bet of all, there are no frequencies to worry about or batteries to charge.
With the DCC signal on the rails all the time, lighted cars are never a problem. With inexpensive function decoders, you can even control them or configure them to behave automatically or simulate lantern flames or EOT markers. Once again, having an on board computer opens up many opportunities for special effects, Sounds can by automatically activated based on the speed of the train, no matter where the car is. The marker lights on the caboose can change colors based on direction. You can even have the pewee whistle on the caboose blow a warning when backing up or acknowledge the engineers whistle.
Beyond small scale thinking.
LGB makes a working DCC controlled side dump gondola. With so many different manufacturers and decoders to choose from, you can now find decoders that operate servos and do just about anything. Add a decoder to a cattle car with a cattle sound card, any you can let operators know when it is time to pick up the car. If it is full of MOO at the stockyard, or is silent at the packing plant, the cattle car needs to be picked up.
With much heavier locos and more pickup point than the small scales, having 20 or more volts on the rails all but eliminates the oxide problems and stalls at low voltage that analog DC and small scale users experience, In fact, Most DCC LS users are amazed to discover their track is usually so dirty that should they try switching back to DC, their locos just won't run without a lot of cleaning.
DCC with it's industry wide standards for the track signal, wets us do things never attempted or even thought of in the smaller scales.
If you are a Large Scale DCC user, what have you found to be different from your small scale DCC friends?
21 - 29 of 29 Posts
Remote uncouplers for DCC have been around for a while.
The commercial ones like Dietz (mini-motor) and Krois (solenoid) are for the hook and loop type couplers, for knuckle couplers I think a coupler mechanism using memory wire is the way to go.
But I have only seen home-built versions using memory wire; like this one for instance:
http://www.rrcirkits.com/uncoupler-electrical.html
There is a fair amount of information on the net using memory wire for various model railroad functions where some movement is required.
Another memory uncouple I have seen is where the memory wire is strung the length of the locomotive at the bottom and activating it uncouples both the front and rear coupler at the same time.
Strangely enough, the Dietz "contraption", which is essentially a small motor and a string to activate the coupler has turned out much more reliable than the Krois uncoupler which is essentially a solenoid.
Knut
Bob,
Could you not manage the lights in a train through consisting? Might take forever for a long string of passenger cars, but if the car consist was relatively static, you could consist those and then form a consist with the engines and cars as two units. The auto recognize function would indeed be a big step forward, and I agree just a matter of time. Once DCC becomes “layout aware” or implements something like Bluetooth, both technically possible today, all you mentioned is possible. I really like the idea of Kadee putting a mechanism in their housing.
Knut,
I found a thread posted way back in 2003 where you posted about automatic couplers http://archive.mylargescale.com/forum/topic.asp?ARCHIVE=true&TOPIC_ID=17692 . Unfortunately the links are not valid anymore and Google didn’t find them. Any idea if they are still around?
Mike
Posted By Mike O on 08/31/2008 3:00 PM
Bob,
...snip
Unfortunately, Consisting locks together the speed and direction of two or more locos, but, the functions only go to the front loco. (only the front loco should blow the horn, etc.
You can program some motor decoders to respond to the functions sent to the lead loco, but that would be expensive to put motor decoders in the passenger cars and cabooses. Function only decoders don't have decoder assisted consisting capabilities.
I currently use a computer to handle all the lighted cars. It's big advantage is that it automatically figures out which cars each loco is pulling. It is easy to uncouple, some cars, add others or change locos wit no need to do anything to make this feature work. Just press F0 at any time, and the car lights behind THAT loco goes on or off. The nice thing is that they don't switch all at once, instead, the go off one at a time as though the crew was going through the train. Another nice effect is that all the vestibule (porch or steps) lights come on when the loco enters a station, other lights go on and off to simulate passengers unloading or boarding. When the train is ready to leave, the vestibule lights all go off and other lights go on or off when the train is under way. The code to do all this is not very complex. In fact, 90% of the code is to decode and encode throttle/function messages. Most command stations run 386's, already do 90% of the work, and could easily handle the lighting logic.
... snip
... snip
There is no need for bluetooth, or any other new technology. All that is needed is DCC feedback through the rails for car and loco identification.
Digitrax Transponding already does that, and the NMRA proposal for feedback would be another way to do it, if the NMRA would ever come up with a standard that was acceptable.
So, being layout aware is not at all a requirement. There is no need to draw complex track diagrams and fill out huge logic tables to tell a computer how all the blocks, turnouts, and signals are connected.
Think of it like this:
You have one extra wire coming out of the command station. That wire feeds an insulated section of rail in front of all of your stations.
Now, inside the command station is a single small routine that monitors all active decoder addresses. This code could be thought of as a robotic controller for all your active decoders. You could easily program all the robotic behaviors like those little stamp controlled robots they sell at radio shack. DCC command station processors are orders of magnitude faster and more powerful. Compared to the complex programs those little robots do, the code to do all of the above is simple. For example, a decoder enters a station track, the robotic code needs to know if it is a loco or a car. Simple, if the decoders DCC speed is set to 0 It MUST be a car. ( something else like a loco had to move the car into the station siding. ) So, one simple IF statement can handle something that would be quite complex in the toy robot world. To do most of the above, the code would, if the address was a car, consist it to the last loco to enter the station. If the address is a loco, remember it's address and add cars to it. Finally, when a function is sent to a loco, also send the function to each non loco address in the consist. In JAVA PEARL or PYTHON that is about 5 lines of code. Probably less than 50 bytes of code in most command stations or hand held DCC throttles.
... snip
Mike
Sorry, Mike, both my web sites got blown away, I think I have a backup on an old computer in the garage, but I haven't been motivated to restore it. I'll keep it on my list of things I need to do.
Thanks Bob,
There has been a good bit of traffic on the NCE Yahoo list regarding the USB connection NCE came up with a while back and it had not occured to me to use a computer to automate some of the functions. Going to have to look into that.
The web sites that I could not find were not yours, they were the two German companies that Knut referenced.
Mike
Hi Mike-
The two companies reference in the earlier thread were Dietz Modellbahntecknik and Krois Modell. Both companies produce uncoupling mechanisms for LGB 'hook and loop' couplers. While the end results are the same, the two designs work differently.
Krois uses a small solenoid coil as an actuator. If you are running DCC, you either need to use the Krois control module or purchase a DCC decoder with a 'timed on' function output.
Krois Modell(solenoid)
http://www.krois-modell.at/main/
Direct link to the Krois LGB uncoupler page:
http://www.krois-modell.at/produkt/digikupp/#gbkk
The Dietz design has a small electric motor which winds a thread around a sheave. The thread pulls the back of the coupler upward, causing the coupler to drop.
http://www.d-i-e-t-z.de
Direct link to the Deitz 'Entkuppler' (uncoupler)
http://www.d-i-e-t-z.de/3_3/dekd2.htm
Here is a sample installation of the Dietz 'Entkuppler' into an LGB RhB Ge4/4III:
http://www.beathis.ch/lgb/23420/23420.html#Entkuppler
Here is another uncoupler mechanism available from Modellbau-Werkstatt (Betram Heyn). I believe the user needs to suppler the actuator - either an electric motor or servo. This mechanis, can cope with 'double hooks' on rolling stock.
http://www.modell-werkstatt.de/lokomotiven/automatische-kupplung.html
Fertig Modellbahnen sells an FES2, which I believe is a motor driven unit. It may actually be the Dietz uncoupler, but I am not sure.
http://www.grossbahnen.de/main_ger/index_bildergalerien_ger.html
(Movies at the bottom of the page)
The FES2 drive the GB2, which looks like the Heyn uncoupler mechanism...
http://www.grossbahnen.de/main_ger/index_produkte_themen_ger.html
If you are into 'homebrew,' here is a Oliver Zoffi model similar to the Dietz design:
http://zoffi.net/MOBAZI/LGB/ideen/kupplung/index.html
(Be sure to click on the "Die Idee | Anprobe | Umsetzung" links at the blotom of the screen. The pageis in German, so you'll need to rinse everything through a translator.
Here is an Oliver Zoffi homebrew motor/sheave type uncoupler used with Kadees. (There is a movie at the bottoms of the screen.)
http://zoffi.net/MOBAZI/kadee/index.html
More homebrew ideas from German Spassbahn members:
Solenoid uncoupler
http://www.spassbahn.de/attachment.php?id=13039
http://www.spassbahn.de/attachment.php?id=1640
http://www.spassbahn.de/attachment.php?id=1646
Another... Note the hook actually articulates upward, for easy uncoupling of rolling stock coupler with 'double hooks'
http://www.spassbahn.de/attachment.php?id=13040
http://www.spassbahn.de/attachment.php?id=13041
http://www.spassbahn.de/attachment.php?id=13183
http://www.spassbahn.de/attachment.php?id=13184
http://www.spassbahn.de/attachment.php?id=13185
http://www.spassbahn.de/attachment.php?id=13186
Downward firing solenoid:
http://www.spassbahn.de/attachment.php?id=2617
Solenoid with linkage
http://www.spassbahn.de/attachment.php?id=2618
Enjoy!
Best regards,
Bob
Bob,
Wow, thanks mcuh of the detailed info. I appreciate it.
Mike
Hi Mike-
No problem. I think it's interesting to see the different solutions to the same problem!
Best regards,
Bob
Knut,
Mike
Sorry Mike - I only check mls once a week or so - somehow this forum has really gone downhill when compared to the early days.
Anyway - the link I think you are referring to in my post on Oct. 7th, 2003 was the original website for the then new Krois automatic coupler.
That's the same one that Bob mentioned in his post with the links.
As far as i know, the heyn and Fertig uncouplers are the same.
Fertig (name of the owner of the store and also the store name) came up with version 1 (FES or FES1) in 1986 and with version 2 (FES2) in 2002. Difference being that FES1 could only be used with a single-hook LGB coupling and FES2 was usable with a dual-hook LGB coupling, but in both cases this was a custom installation by Fertig.
Starting in May 2007 Fertig and heyn are offering the FES2 "pre-mounted" , as they call it, for people to do their own installation. But you still need a separate solenoid and of course some way to drive the solonoid.
As I mentioned before, I personally prefer the memory wire approach. That should work with a knuckle coupling as well. It's extremely simple and if you pick the right decoder you can activate the memory wire directly
Knut
21 - 29 of 29 Posts
