1 - 20 of 26 Posts
Jason, I'm hoping you read the recent threads about types of batteries and recommendations.
I'd say there is a wealth of knowledge there.
Also, before you decide for yourself, you need to look at how YOU will be using batteries, like trailing car or not, what you budget is, how long you want them to run, will you be using sound, what kind of grades you have and how long of a train you want to pull.
If I just told you I use 7 amp hour gel cells, it would be no use to you if you did not want to run a trailing car, for example.
Sure, tons of people will jump in and tell you what they are using, but only information from people with SIMILAR requirements will be of any practical use to you.
Hey Greg,
I read them. Was just wondering what everyone is useing and what they get out of them performance wise. I am looking more and more towards battery r/c over dcc. Want everthing thing onboard diesel. Wanting 2 hours or better, have a long grade up my side yard not sure what percent but it rises about 2 ft of elevation in about 50 ft. Looking toward Airwire so have all dcc functions. Jason
Jason,
Greetings from the Upstate!
I use the RCS brand of RC and usually 14.4v for all my installs....I am a NG Steam guy, so my info will prob not fit your parameters, though I am planning on getting around to re-converting my GE 45 Tonner from a trail-car set to on board-close but no cigar.
My Bachmann Annie usually gets about 3 to 4 hours running on one charge (14.4v). My HLW Mack (9.6v) runs for nearly 6+ hours on a real good day with two or less cars. I've powered with NiMh and NiCad...both have served me well, I owe a ton of gratitude to my MAHA brand Battery Charger for that.
As a happy customer of RCS (Tony Walshman-mfg) and NWRCS (Dave Goodson-my RCS Supplier) I'll share a few install links that may be helpful (with any brand control)
these are all diesel installs:
http://www.largescalecentral.com/LSCForums/viewtopic.php?id=9007
http://www.largescalecentral.com/LSCForums/viewtopic.php?id=7629
http://archive.mylargescale.com/forum/topic.asp?TOPIC_ID=24175
http://archive.mylargescale.com/forum/topic.asp?TOPIC_ID=35848
http://archive.mylargescale.com/forum/topic.asp?TOPIC_ID=23020
all of the above can be found under the Batter/RC tab here:
http://rcs-rc.com/
Good Luck!
cale
Airwire in a trailing car with a 18 volt drill battery. Been running that way for 4 years been very happy with it. I have the Airwire, and P-5 on
a piece of plastic so I can move it form one car to the next.
Thx for everything guys Cale the links are helpful. The 1st engine is a aristo gp40 rebuilding with a high short hood for ex.Norfolk Southern plan to have batts onboard but also bulding a rpe4d ex. NS slug to go with it for heavy trains extra traction and battery car.
Thx Jason
I have a simple answer for you Jason, you made it easy, thanks!
4% grade.... big grade
in loco .... smallest battery size possible in relation to power
2 hours... relatively hefty requirement considering the 4% grade.
Lithium ion packs, depending on the control system you use I'd say 18 - 24 volts. If you were running NG trains I would say 14-18v.
Have fun!
No batteries in my locos at the present. Just about 30 years of working with them! I've designed hardware with all different battery chemistries. I have about 500 rechargeable batteries at my house, and more chargers than I want to acknowledge.
I'm not a good candidate for battery power.
Jason.
Since I did that G-40 installation I have designed a produced an ESC specifically for the AristoCraft locos.
The RCS PnP-3AC.
This is also Plug'n'Play with the Phoenix P5 sound system.
I have also devised a better way of mounting the receiver part like I did in the SD-45 or Dash-9 using an AZARR 27 Mhz antenna.
Posted By Greg Elmassian on 03/09/2009 8:47 PM
Everyone is a candidtae....ask Goodson
Master of Disaster
Bull, I use Airwire in a trailing Bx Car. 18 volt Milwaukee batts, and charge them with a 3 bay charger.
With 2 GPs' I get 1-2 hours.
I have all the RC units EXCEPT for Loco Link.
My system of choice is Airwire...simple install, in a boxcar, no hassles with anything....BUT all the other R/C units offer various pleasing options, it's just what you like.
I never have to use any noise suppression electronics and my range is superb...best of all I like all the sounds I can activate with the hand held, the P-5 is AWESOME!!!!
Milwaukee batts and the charger on Ebay are pretty much not a real big expense...either click on the links, and if that doesn't work cut and paste seperately these 2 web addresses in your browser to get to the Milwaukee batteries and charger.
http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=Milwaukee+batteries&_sacat=See-All-Categories
http://shop.ebay.com/items/_W0QQ_nkwZmilwaukeeQ20multiQ20bayQ20chargerQQ_armrsZ1QQ_fromZR9QQ_mdoZQQ_sopZ10
Hope this helps
IMHO
Bubba
I have big rechargeable pack in the tender with an Aristo Trackside receiver. Runs my Mallet 2 hours or more with smoke and lights. I lift out the coal load to change packs and charge one while running another.
Discussion Starter · #17 ·
Sweet thx guys good info. Going to open up under the dynamic brake for easier battery changes instead of the whole shell just lift off dynamic brake hatch should work. Useing rare earth magnets to hold shell down on slug for easier battery changes in it to.
Later Jason
Posted By bull on 03/10/2009 2:47 PM
How do you make a working link?
type [url*]link goes right here[/url*]
but do it w/o the *, yep remove the * from the above in brackets and you got it!
for pictures it's the same idea but IMG instead of URL...for instance....
[img*]picture location here[/img*]
just remove the *
cale
1 - 20 of 26 Posts
