Posted By blackburn49 on 04/06/2008 4:26 PM
Posted By toddalin on 04/06/2008 3:32 PM
Posted By Ed Harvey on 04/06/2008 12:56 PM I want to put a small pond on my layout but I'm not sure which is better and EASIER - a pre-formed plastic pond insert or to use a pond liner? Any thoughts?
Neither! The cheapest and maybe most realistic method is to "hand slap" your own concrete into any shape you desire. Use a "chicken wire" frame for steep vertical sides as necessary. You can texture it using crinkled aluminum foil pressed into the setting concrete. Alternatively, when the concrete dries, apply a "thinned" layer of mortar/mason's mix on top and texture that. You can also add dye to the concrete/mortar so the color goes all through. Alternatively, if you want to leave water in it (or have fish), paint it with a coat of "Drylock" which makes the masonry impervious to water. You can add color layers of ordinary house paint on top of that. If your masonry cracks, you can use "Drylock hydraulic cement" to fix the cracks (can even apply it underwater!) All of our lakes, rivers, and even ridgelines have been done this way with good results.
Great suggestion. I will consider this method for my Phase III model RR line. As always, the garden model RR construction methods brought forward here on MLS are excellent.
Additionally, if you're building a large pond, consider construction with gunite over rebar. It's very fast if you use a commercial gunite applicator. Build in provisions for bottom drains, plumbing, and skimmers before applying the gunite.
With any concrete product spraying a rubberized overcoat is something to consider as well.
