I have just found the third axle [from two cars] on my Bachmann 3-bay coal hoppers that was shorted across from wheel to wheel. The first one I found had some trackside wood bark smoldering, melted the truck journals, and tripped the circuit breaker on my power supply. Since then, I have found two axles on a second car that were shorted. When the offending wheel is removed from the axle and a battery and voltmeter test is done , there is voltage transfered between the outside of the wheel and inside of the plastic bushing at the center, to the axle. I guess the entire set of hoppers will have to be checked for conductivity across the axle and wheels.
Note melted journal and pitted wheel:
Ordinarily, this would not be a problem for me running track power. However, one of my lines is track power capable for visitors. This is when the short happened.
I contacted Bachmann 2-1/2 weeks ago [ 9 days before Marty's] and got a less than satisfactory response. First there was an attempt to blame my MRC power supply. When I refuted that idea, I was told to send in the offending parts and if they agree, a replacement would be returned in about four weeks from date of receipt of my parts. The fact that I wanted to take these cars with me to Marty's, was of absolutely no consequence. As example of better customer service, another company making Garden Train products has even given overnight delivery of replacements when there were exceptional circumstances.
To those of you that run track power, I suggest that you check any of these cars you have to make sure "magic smoke" doesn't show up on your layout.
Has any one had a similiar problem?
JimC.
JimC.
