Hello everyone! My name is Spencer and I am a 24 year old mechanical engineering student living in Cincinnati. I am not new to the hobby (started building by RR 10+ years ago) but this is my first steam loco.
I recently purchased a used Ruby on ebay and have several questions. Seller claims it has a 60 psi safety valve, Accucraft pressure gauge, and upgraded to 0.5 in cylinders. Both cylinders seem to have good compression. Checked function of reverse valve and it seems in spec.
I am referencing this video:
1. A goodall valve has been fitted and appears to have mineral deposits/slight corrosion. Is this normal for an older loco or is it a sign of improper operation? How can I check the boiler for scale and clean it if necessary? Or should I just return the loco?
2. Are all safety valves similar to the one in the video? In other words, do I risk damaging mine by disassembling it to check its operation?
3. Does anyone know how old/which model it is?
4. The loco was packaged on its side and very oily with discoloration by the fire box. What is the best way to clean it up?
5. A few screws are missing (one holding the cylinders to the chassis, one holding the bumper, and the firebox door latch). Where is the best place to acquire these?
Thank you for the help!
