I'll try this again, but I'm sorely tempted not to...
I've had some glued up 1X4 panels hanging around for a bit now, which have gone through the thickness planer, 15 degree, 3/4" dado cutting to mimic clapboard siding, and now I decided it was time to get creative.
Most of the others that got the dadoing treatment also received some mind numbing Dremel saw activity to make them into shingled roofing panels. However, I digress again.
This one plank (three 1X4s biscuit joined at the edges) has been begging for attention, so I got bizzy with the whirlying silver colored disc, with no clue as to what this thing will turn out to be. I'm open to suggestions....
The only problem was that at roughly two stories tall, It either was going to need a flat roof, or I was going to be making up more panels that were five 1x4s edge to edge.
I chose option "C".
I cut some lengths (sides and ends), and kept a salvage piece the same width as the two ends. These were biscuit joined onto the tops of the end pieces after trimming all of the pieces to the same height dimmension, (clearing off the "rough" or uneven edges),
It's gonna be tallish, with two levels (floors) with windows , and an "attic" set of windows in the gable ends.
Then I had to figure out how to join the corners, and keep everyting together. I don't even want to discuss the "learning experience" that I've received from my first project using the "shingled" look of the 15 degree, 3/4" dado trick. Can you spell pagoda? Or double sided ski jump??
Bisquits it is, to which I'll be adding in some corner blocks from top to bottom. Plus some other internal blocking/bracing to keep all the wood "cross-stressed" (NO!! Not "cross-dressed". Preverts...)
Here's where I am so far.
Remeber the discussion about thickness planer and dado cutting?? That removes material, and if you don't do a test cut in a "scrap" area, you'll find out that you've blown through your work piece, even if you're set to a "0" sized bicuit... Just like the above picture. Glad I wuz thinking today... As it turned out, a few of the cuts actually *did* come through, but only in little "spots". I can recover on those, as they are hardly noticeable. Just got to look out for glue squeezing out...
You'll have to imagine the peaked roof. Figure about 45 degree angle (whatever that equates to in pitch for you carpenters out there. I suppose that's a 12-12??).
Anyway, I'll add to this as I can, and am open to suggestions for it's purpose. The dimensions are not quite correct for Reilley's Jewelry and Pawn Shop (or whatever I originally called it), but let's have what you think. Other than the gallon 'o gas and a match deal, okay?? /DesktopModules/NTForums/themes/mls/emoticons/whistling.gif
Thanks kidz!!
I chose option "C".
Thanks kidz!!
