So if i wanted to put in a sideline alongside my mainline and using USA #6 switches im a bit confused on what dia curve you use to turn the track back so its running parallel with the main...make sense?
after the switch (right side for line on inside of clockwise running oval) which is a 4' dia, what dia curve is needed ? a 4"?
then to run the sideline back into the main do i need the opposite direction turnout?
thank you
thank you
