Hi,
I've spent hours upon hours cruising the forums here and browsing manufacturers websties trying to sort out all the options available to power our trains. I think I've got the general idea but a few things still confuse me. I'm trying not to ask questions that have been answered hundreds of times already, so bear with me. I have done lots and lots of homework already, but there is still so much more to know.
What I want: To run a lash-up of multiple engines like the prototype does and do so with a wireless throttle. Multiple trains on the same track is no my concern at this point. I'm just starting out so I'm leaning towards DC as it's simplest and cheapest and gets trains running.
Now. Can I lash up multiple locos, say 2-3 Dash-9s using DC power and a Aristo TE and expect things to run well? I understand I need a sufficient power source to run multiple locos of course (thinking meanwell S-320-27). I realize this still relies on all units in the consist to run at comparable speeds so running an Aristo engine lashed to a USA engine is probably not advisable in this scenario.
All of this leads to my next question. What is the purpose of running a QSI (or any DCC for that matter) decoder in your locomotives if you're running DC power? If I'm running DC, and install QSI decoders, and have a wireless throttle, will the QSI system allow "consisting" or linking all the engines so that they receive the same commands and run at the same speeds? With this setup, would I be able to run Aristo Engines and USA engines in the same consist and expect them to run at exactly the same speeds without fighting against each other? Do I need a G-wire chip to run QSI decoders with wireless throttles? Is there a significantly cheaper decoder that doesn't have the sound included that I could buy instead of QSI that would allow me to consist for less money?
Another thing. If I start with DC power, then eventually install decoders, how hard would it be to someday switch to full DCC at this point? Or maybe there is no point in going that far and not going full DCC. I'm assuming this is simply a matter of changing a few wires inside the locomotive. I'm trying my best to start out small and on a budget, but at the same time not limit myself for future upgrades. Please keep in mind I have next to no knowledge of electronics, so simple language please. Soldering and switching wires and programming chips is not my idea of fun and definitely not why I got into this hobby.
This is all very confusing and I'm still trying to sift through and sort out technology names vs. product names and all that stuf. BLeh. I won't even get into some of the other questions I have right now, I think this is enough already. Thanks in advance for any help.
