1 - 8 of 8 Posts
I have a 6" x 6' maple board. I'm going to cut it in half and then I'd like to use some dowels with glue to make one 12" x 3'. The problem I'm having is how to make the holes for the dowels align perfectly so when the boards go together they align perfectly?
Any tips or tricks on how to do this?
A Steamed Elder
You don't even need the drill points. Just use the drill fixture. If you line-up the fixture with your match sides and drill, the boards will fit perfectly. I've been using these for forty years without points. You can find inexpensive doweling jigs at most home centers, made by General, for about twenty bucks. Nice tool to have in the box.:D
jimtyp
You can also use a biscut jointer for this. They work great. The jointer cuts a oval slot in the edge of the wood and you glue a biscut in these slots. Maybe you could borrow one.
when you glue your board together, look at the direction of the end grain. Try to have one board with the end grain curving up and the other board with the end grain curving down. This will help keep your glued together board from bowing.
In the past, I have used splines cut from hardwood. For 3/4 inch
boards I would use a spline tha is 1/4 inch thick by 3/4 inch wide. This puts the spline about 3/8 into each board. I had good luck with it. You can cut the grove with a winged router bit or us a table saw, the cut a spline to fit.
Biscuts pretty much replaced these techniques. The best would probably be a glue joint router bit after jointing the edges.
1 - 8 of 8 Posts
