1 - 6 of 6 Posts
Anyone have good tips for gluing a vertical post to a side sill. End grain on a post is always a problem and I have 13 to do. First trial attempt failed. I have thought of gussets but these will cause interference with box that the post/side sill goes around. Notching the side sill is out, posts would be too short and not per the prototype
Any ideas would be appreciated
Thanks
Dave
In situations like that I have used short pieces of brass rod as a pin, drilled up in the center of the post and drilled into the sill. This also gives horizontal strength to the joint.
Rick
I'm assuming that this is for outdoors, correct?
If so, given the small surface areas involved I doubt that any glue will hold over the long term. Perhaps something that is polyurethane based like Gorilla Glue as it is a bit flexible and I believe UV stabilized.
I'd recommend that you consider also pining with either the small brass rod as suggested or use a 23ga pin nailer
Loggerhead,
dampen both the end grain and the area of the 'T' joint, apply the Groilla Glue to the end grain side of the joint. Assemble in a fixture, and then pin nail with a single 23 gauge pin to maintain alignment until the glue sets. This is the process I use, and others that typically build in wood for outdoor use..
Bob C.
1 - 6 of 6 Posts
