21 - 24 of 24 Posts
They are all similar to each other to the point where a non-railfan would likely not be able to tell the difference.
That's true, and it applies equally to the Connie. Letter it for the D&RGW or C&TSR (I know, blasphemy, but we're talking about low-tech and low-budget solutions here) and call it done. I may still have a wood cab around, which would backdate it to the Silverton Northern No. 34. PM me if you want to try that.
http://web.archive.org/web/20050208030739/http://www.nmia.com/~vrbass/fhpb/
Here is a photo of a Connie that I converted into Mexican National RR #291. I had a build log of the entire train under the Master builder forum but unfortunately most of the photos have been removed except for the locomotive and the finished train. By the way I did replace the drive axle with one that has the brass gear. It is quite easy if you can get the part from Bachmann.
21 - 24 of 24 Posts
