As an experiment, after cleaning scrap brass w/ vinegar, I used straight Brass Black. Blackened very well, but flaked off some. Next, I'll try the suggestion of a diluted mix; 10:1 w/ water, a little salt and a few drops of vinegar added. How much salt? Is table salt okay? Also, these are 32" long pieces of brass, 3/16" wide, 1/32" thick. How long does it need to soak? Can it be brushed on and let sit for a while? How long? Should I make a 32" styrene tray to hold enough solution to completely dunk/soak the piece? Let it sit in the tank/ solution for a while? Will it attack the epoxy used to secure the white metal tank hardware? I have eleven bands to blacken. Do one at a time? A few at a time? Still a diluted solution? New solution for every band?
Brass Black did nothing on the white metal. Could not find Pewter Black or Pewter-It locally. Did get Blacken-It. What are your techiniques for using Blacken-It on white metal? Many of the same questions a above; soak? how long? will it attack epoxy? etc.
Thanks, Tbug
Oh - I am also going to paint an HP resin tank spout. Suggestions on what type of paint? Any reason not to use Floquil primer and paint(s)?
Thanks, Tbug
