1 - 6 of 6 Posts
I have the 2 axle version and had issues with stalling at low speeds on plastic switch frogs.
My fix was to swap the wheel/axle combo from front to rear. This was due to the power pick up from the insulated (wheel with traction tire) being far away from the slider.
I have done this to at least 6 of the 2 axle versions with a big improvement in power pickup.
If converted to battery, yhe power pick up does not matter!!!
PS I have found this engine to be an excellent puller of trains, comparable to the stianz and forneys.
Posted By Bills on 01/01/2009 3:39 PM
Stan
How do you detach the front hand rails from the body to do the dcc conversion?
Bill
Bill - I had the same problem. Believe it or not, they just pull out. The problem is a crimp on the other side of the shell, so it takes much more force than you usually would want to apply, but it will come out. Then I just cut them a bit shorter so they no longer go into the shell, allowing me to remove the shell for servicing.
1 - 6 of 6 Posts
