I have a LGB 21791 Corpet-Louvet (with a factory installed decoder) that I am using with a LGB 4135s (analog) sound car under analog track power.
The sound car starts chuffing before the loco starts moving.
If I reprogram the decoder to start moving the loco at a lower voltage will the loco also start at a lower analog track voltage?
Since the sound card does not have a decoder or chuff control I cannot reprogram it (except that I may try changing the chuff start rate by adding a resistor).
The simplest solution seems to be that if I can get the loco to start at a lower voltage it might better match the chuff rate of the sound card.
The instructions for the 21791 Corpet-Louvet show:
CV2 Starting voltage (0-255) [5]
voltage for speed setting 1 - if loco starts only at a higher speed setting, increase value.
This suggests to me that changing CV2 to a higher number would start the loco at a lower voltage and that setting CV2 to 255 would start it at the lowest possible voltage. Is this correct or do I have it backward?
Is there a negative side to doing this and would it affect operations in both analog and MTS?
I don't want to "just try it" because similar efforts with other locos have resulted in unexpected problems that were hard for me to get rid of.
Jerry
Jerry
