1 - 4 of 4 Posts
I just bought a well worn Stainz 0-4-0 and went to test it. Using a Bachman 3amp variable power supply, the voltage goes up, the amps stay at zero.
I even hooked up the power by a set of test leads to the skates. No joy.
I've used this power supply on LGB locos in the past and there was no problem.
If I remember my basic electricity, zero amps means that the motor is not getting connected to the power.
So, before I tear down the loco, are there any tips and tricks.
And any tear down advice? I should be able to find a parts diagram somewhere on the net.
Thanks in advance
WES
Discussion Starter #2
After the teardown, found the motor turns stiffly and does not run when power applied direct to the two brass power pickups (that go direct to brushes) - now looking for an upgrade motor or replacement.
Discussion Starter #4 (Edited)
Never leaving well enough alone, I kept digging.
Finally found the culprit: the brush spring on the 'red' side has no tension, so the brush does not touch the commutator.
1 - 4 of 4 Posts
