1 - 16 of 16 Posts
I am in the process of building a 1:20 Water Tank, and am in need of a water spout. Have had the HP spout on order since December but they are having vendor supply issues. Doesn't look like one will be delivered any time soon (or at all). Any ideas for another supplier or way to scratchbuild one?
Thanks
Posted By rkapuaala on 06/20/2008 8:44 AM
Brian,
What diameter of tubing did you start out with?
Its 1/4" ID copper tubing (about 3/8" OD). Pipe is measured OD and tubing is measured ID if I remember correctly. That size worked out to about 9" OD in 1:24 scale which seemed about right.
I just last night read in an old back issue of NG&SL Gazette a how to: Briefly, if you want to fab it up out of brass, cut a piece of paper for a pattern. It should be a trapezoid so you get the taper. Play with the paper cutouts until you get what you want. Then you use it for a pattern to cut the brass and roll it up and butt solder it.
For my part, the suggestion on the 1/4" copper tubing is the way to go.
Les W.
1 - 16 of 16 Posts
