1 - 8 of 8 Posts
I bought mine from a man in Australia. Are they still being made? Contacts? Thanks
Accucraft Ruby, Accucraft 1:20.3
I've been researching them. I have no idea if he is still doing them, but the Australian website is still up.
As far as I can tell his setup only fit under outside frame locos, or in cars. I'm starting my project of building one to fit my Ruby. If I can do that it should fit anything.
Don't expect fast results on my project, in a little over a month my busy season will start and I'll be lucky to think of trains for 8 hours total in four months.
Tyler
I think Terry makes them for specific locos, and many locos used in Oz have outside frames as they are 32mm or 45mm gauge adjustable. A unit designed for a 32mm outside frame chassis should fit any 45mm gauge loco? But don't listen to me - ask Terry!
P.S. There are other inertia/drag solutions. Take a look at this:
Drag/Inertia Car
I chose to build mine into a trailing car with Larry Green's help and John Raffe's inspiration. I will build two bodies, one for each of the scales in which I most frequently model. That way I can use it with any loco I wish. It must have a solid connection to the loco and sufficient weight to function properly. It took a long time to get with Terry's work schedule so patience is called for.
I'm very interested in one that is tied to the drive train of my Ruby. Even after doubling it's weight, it just does a burn out until the consist has gotten to half speed.
One time (foolishly) I was running the Ruby without any cars. It will do a solid burnout for 4 feet. Then after accelerating, I locked up the wheels and it slid for 8 feet.
Needless to say, I need to tame my Ruby in a manner that does not require traction. Also, my end goal is to use it as a switcher tank engine setting up a train for my bigger line locomotive. So it will spend some time uncoupled and I like the smooth, slow movements of this one.
Video of slomo switcher
You are having fun. Have you looked at the improved throttle spindle that Jason at TTD sells?
The Train Department - Live Steam Locomotives and Steam Accessories - TTD Upgrade Valves
I think adding a Slo-Mo type of flywheel under your loco would definitely improve its control. I would think Terry would want to make one available for the Ruby - there are a lot of them tearing around all over the place.
Adding them in a trailing car is problematic due to friction issues. My drag car is very, very heavy. Much better to put it where the problem is - in a drive axle.
Terry (Mr Slomo) is still in business. He recently moved house which has slowed production.
He has also updated the design, as seen in a youtube video
Mike Bickford
Murrumburrah Tramway
NSW Australia
There are problems with trying to fit a Slomo to a Ruby/ Mimi locomotive. The center line reverser valve and eccentrics on the axle are in the way of putting a Slomo unit on these engines. I have an Accucraft Earl fitted with a Somo unit and it fits between the frames very snuggly . I also have a Accucraft Mimi and can not see anyway that a Slomo device could be put in place between the frames and clear the reverser , eccentric linkages to the valves.
Charles M
1 - 8 of 8 Posts
