1 - 13 of 13 Posts
In an effort to compete with the out put of the Dewey shops, Shagamauw Lumber of Rogue County, California, raced to the task of creating a 2-2-0 like Stan's;
http://www.mylargescale.com/Community/Forums/tabid/56/forumid/8/postid/67345/view/topic/Default.aspx
Unfortunately, there has been all too much celebration in Rogue County of late and the lumber boys not only got the idea turned around (they built and 0-2-2!), the even put the boiler on sideways!
Made of whatever leftovers could be found in the yard, the new (as yet unnamed) loco was immediately put to work on Shagamauw's new track.
If it weren't for the coupler and the light, you'd never know this was the front!
The engine rides a mite high, but looks like she'll do to haul the empties.
The boys were a bit dissappointed that she didn't come out near as purty as Stan's, but they love her just the same.
And as far as the rest of Rogue County, well, they think this lil' gal fits in just fine.
Chris
It would appear that the Rogue County boys are much more adept at laying track; considering that none of that was there yesterday.
As usual, pictures can't do it justice. I can't quite count the cars; it appears to be nine? If so, good on ya' Rogue County boys!!
If its track powered I would suggest not running it on switches. I have found very short wheelbase engines are very very prone to stalling on the frogs, my 2 little MDC speeder based Critters and Dinky, my loco bash based on an HLW ore car and an HLW railcar drive, both with very short wheelbases, just refuse to cross the plastic frogs on A/C and LGB switches without stalling, so they are dedicated to running on the portable layout. Chris's creation is half again as short as mine so I would expect similar results once the wheels hit the plastic frog on any switch, keep it on a switchless loop or do like Stan and add a trailing car for batteries, then it could go anywhere
Delightfully Delerious Chris, its great to see you back at work as your such an inspiration but as such, your also a very bad influence on me, you keep giving me ideas ....its partially your fault I have so many zany engines and no finished layout to run them on, oh well, life is hard right?
1 - 13 of 13 Posts
