Posted By rsmproductions on 01/26/2008 8:33 PM
Greetings Everyone,
I haven't been on the site seriously for some time and am getting used to the new look...so far so good. Oh...by the way...Happy New Year!!
I would like to delve into the world of scratchbuilding structures and rolling stock soon and would like to know what kinds of tools, both power and hand tools are a wise investment. What do you use in your scratchbuiding projects? I have the basic circular saw, cordless drill and even a Dremel tool, but would like to know what else is necessary.
I appreciate any suggestions you have.
Richard
I have a band saw..use it little...I have a combo sander, disc/belt by Sears....use it alot!!!
Here is a site devoted to modlers..called Micro-Mark...is it cheap...NO, but you can see what you need here and look at stores like Harbor freight to see if they have simular items...which if they do the tools will be WAYYY cheaper!
(see next link)
http://www.micromark.com/freecat/mmfreecat.html
This next link, AT Micro-Mark has proved itself to be my MOST useful tool!
Cuts plastic or wood metal...no./DesktopModules/NTForums/themes/mls/emoticons/pinch.gif
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=50348
As far as have to have OTHER tools:
(In addition to Altterain's suggestions)
Pin vice for using hand controlled drilling
Dremel set of small bits
Dremel kit the more you have the better...ie cut off wheels
Hand clamps if you glue ..med to small that are used for holding wood while it dries...check
Lowes for the rubber tipped ones.
Tape various kinds....white, blue,and purple various sizes for various jobs.
Measuring devices various sizes
Vice very small, for small work, larger one for BIG work, (latter is optional)
Clamps various sizes...very small to med to large
Files I have found that SOME hobby shops carry med sized boards that look like oversized nail files in various grits.
(for scratch building I have found that these come in vary handy)
Sand paper 600 grit or higher wet/dry sand paper, but don't forget the lower grit for taking off large amounts of "stuff"
Clothes pins wrap a rubber band around them to give them MORE pressure for holding
Glues Various super glues for various jobs, Emblem glue (bought at NAPA auto stores)
Epoxy (5 minute) this is also one of my best tool for modeling..even with its "5" minute claim, still takes a long time to cure
Tooth pics flat and round, stored in salt shakers, for easy removal
Q tips for what you don't think would need them for
Reserves minimum of 4-5 OR MORE deep of any paint inks, glues, files, etc ANYTHING that when out would hamper you doing a project
when the "mood struck"....usually doing a project when the "mood strikes" is the BEST time to do so...as that time is the time when
the "best" work is produced!
Paints water based AND oil based...water base clean up better in the airbrush!
Dull Cote..( I usually have this 25 deep, as I use alot of it)
Thinners Large containers of laquer , paint, mineral spirits
Compressor for painting..(rattle cans don't give a "realistic" appearance when used for weathering), I don't follow the 10' rule!
Double Action airbrush makes painting dust on a project look more realistic
Single Action Airbrush for spraying large areas that looking "realistic" isn't a priority
Chalk various kinds I use the sticks used for drawing sold at Michaels....I also find that storing your chalk in very large sized containers so
that you can actually chalk your whatever in helps to keep the over dusting contained in the very large container and
you can keep each color you use seperate, and the containers are stackable
..( won't work if space is an issue)
Pigments' they usually stick better then the average garden variety chalk (when using Dull-cote chalks tend to "dissappear" more then pigments)
Brushes for applying the chalk, they can be left inside the container.
Spray Booth for venting fumes outside to keep from inhaling toxic fumes and to keep chalk from setting ALL OVER EVERYTHING!!!
(chalk is soo fine that it will cover places that you can't even see! EVERYWHERE)
Paper plates for mixing paints etc..in various sizes from bowels to small paper pie plates
Turkey pans (large) If you use an alcohol bath to weather your trains I find that these are SUPER for catching the overspill so it can be
poured back into the india ink solution container.
Bins Walmart sell various sized hinged top containers to store any parts, supplies....what ever it is that you would have to have on hand
in an orderly fashion, so you don't tear your shop apart finding what you need!
/DesktopModules/NTForums/themes/mls/emoticons/crazy.gif
Hemostats can't say enough about them, I use them for everything!
Remember the days when they were used for OTHER things then modeling??????? (the good OLE days)
Note: Dull-Cote is the only clear sealant that I have found that gives me that whitish dirty look upon evaporating...as seen on every road weary steam locomotive...I have tried them all....if that is the look you are looking for........if not never mind! As Mac would say
"I likum dirty"
I find all these tools mentioned help me turn out what I feel are quality projects...although this statement is subjective to other's!/DesktopModules/NTForums/themes/mls/emoticons/hehe.gif
Keep your eyes open as you can find things that you can use when you arn't even looking for something!
Hope this helps!
Bubba
Thanks for whoever fixed my crookedness.
