1 - 20 of 80 Posts
Well after years of waiting, I finally am trying my first build. It's very inspiring to see what you guys can build. Here's a start finally:
Going to be fun trying to make the panels.
Now that you are that far Joe, how does your cab compare to the CN cab you bought?
Seems that the nose is a bit longer than on a CN unit.,... ey'!!
You'll get me cutting plastic soon; let's see clean off 2 work benches, find time, wait till it cools down, install a cooler in the shop, fix the band saw, work on Matt's DDA40X, work on My layout, work on the SD90 loco - OH here we are,... under - build a 70ACe frame!!!!!!!!!! that's it! And a bunch of cars to paint...........
I'm sure I must have 'left' time in here somewhere, if I could just find where I left it!!
Dirk - DMS Ry.
yeap, I went downstairs to grab an O scale model to guide me!
I have a bunch of projects and they got moved to the backburner now that I've got some plastic!
The biggest difference I think, is the nose is much higher. Joe
You've got me thinking now Joe!!!
Between a bashed up 70 cab ......
OR
Cutting plastic for a cab.....
1st try is mostly a proof of concept anyways!
Any added work this long weekend from you?
Dirk - DMS Ry.
I filled in the nose area where there's another angle..... I added holes for the sand filler pipes...... now I'm cutting the sides of the long hood. There's a grill on the long hood behind the cab up high near the exhaust.. I can't tell what's behind it... some kind of shape that looks like a crown???? I'm thinking it's the way the side is cut for airflow???
Discussion Starter · #18 ·
USA on the dynamic brake (1/29), the reg fans are Aristo just sitting in until I make some. I have a nikon if I could just figure it out. I'm trying to show the whole engine in 1 pic. What should I take a close up of? Something you'd like to see better? I think the picture size reduction ( to meet the rules), changes the quality a little? The top pics look better though?
I have an older Nikon - Cool Pix 8700 - that has a 'close-up' dept. to get real close to stuff, like 3/4" from a lizards face. I use it for lots of my model work shown here..
So get the cam up and running and I'll get you pointed at what I think I'd like to see - closer - of your great work!
Dirk - DMS Ry.
1 - 20 of 80 Posts
