1 - 12 of 12 Posts
I am working on a long term project to create a "g-scale" Chicago El train. I have received drawings of a 5000 series car, imported them into Adobe Illustrator, and begun to trace over the top and create dimensions for 1/32. The process I went through was to draw a 45MM rectangle reflecting the track gauge, placed that between the wheels, scale the drawing for a best fit, and then draw lines and measure in MM through illustrator. You can see where I started and where I ended below. After doing this I have a few questions from anyone that has taken the same approach:
1) Is starting with track gauge and "eye-ing" the location of the wheels appropriate?
2) I am scaling to 1/32 since the Elevated Trains are Standard gauge... that said I recognize it might be best to use motor blocks from USA Trains (NW2?) or LGB which might challenge my current scale. How does one come up with the right scale? There are a few measurements in the plans that I could have anchored on like wheel size of 28"
3) Where are modelers more precise vs. let things just fit? As I started the process I thought gauge was most important but as I have continued I am wondering if I should have tried to anchor off wheel size since I will probably use pre-built motor blocks. My current plans have 2.45" between wheel centers; the NW2 trucks appear to be about 3". Wonder if I should redraw with those dimensions?
4) Are there motor blocks you might recommend I should use?
Appreciate any help, this is a fun process but I am trying to figure out the right way forward.
Rectangle Font Schematic Parallel Engineering
Rectangle Font Parallel Engineering Schematic
Kevin
My real job is freelance design, mostly packaging. I use illustrator daily. It's by far the best vector drawing program. Personally, I would size to the overall car length. Can't speak to the motor blocks. I 3D print mine. What are you building with? Styrene? Brass?
Take a look at the Hartland ones, which are in quite a few models so you should be able to find some.
And note that our wheels have larger flanges. If you use scale wheels (e.g. 28" over the treads,) then the oversize flanges may cause clearance problems with bodywork, etc. It might be better to use slightly undersize wheels so the overall outside diameter over the flange is the same as the scale size.
Thanks, good to know it is the right software. The cost is relatively high for a casual user and I am not a fan that Adobe has gone all in on the subscription model. Using the 7 day free version for now and hope to get plans done before it runs out.
Not sure how I am going to build it yet. I dream of doing it in brass but I need to investigate how I can appropriately get the bends I would like. I am very much an amateur at this and one of the goals of this model is to improve my skills.
Will do, thank you for the assistance again! Will do on the flange sizes
It's your personal preferred drawing program, right? I use Visio, which is now owned by Microsoft. This EBT M-1 drawing
Rectangle Font Parallel Pattern Slope
was exported as a DWG file and sent to Alan at G.A.L. He laser cut the model parts. (Yes, that's a lot of rivets. About 1,000 each side. The laser cut the holes - we had to apply the rivets!)
I use Illustrator because it's industry standard for creating printing files. I have to use it in my business. I've used it since it was Aldus Freehand. Before Adobe bought Aldus. Vizio is aimed at flow charts. I imagine both will work for model drawing.
Lazzy man method.
My very simple technique to boost scale on drawings isn't extremly precise, but it is sufficiently so for most of what we modelers can do:
I take a scan of the drawing at whatever scale it is. I take a given dimension on that drawing and calculate how may inches or cm it would be in 1/32 scale. ( IE the wheel base or lenght over buffers or couplers. I preferably use a long dimension rather than a short one like the track gauge as otherwise there can more easely be an error) then I use Paint to blow the immage at whatever that dimension should be. Once I obtain that I make a test print, to see if the dimension on the screen matches the printed dimension (sometimes it doesn't) and if it doesnt I compensate by adding a few percent or substracting a few as necessary until it fits the dimension I want to obtain. For long things like a 85' coach I print in sections which I then past together. This crude method works very well and is sufficiently precise to build gauge one rolling stock to accurate dimensions.
Get to the workbench!
I have never used Illustrator. I'll have to try it
If you can get the length or height dimensions, that is the best way to go. Just divide by 32 to get the measurements. The next best thing id the wheel tread diameter. Use it yo get your drawing scaled but because of the flange difference, you may need to go with the wheel size that looks and works best.
I use IrfanView a free program that will print to any percentage of your scan. I print one drawing and measure my length, height or wheels and then reprint at the correct percentage.
If you have CAD, you can use the scaling function to do the same thing
Showing your age Pete, "now owned"? I was around when the purchase was made, programming. 22 years ago....
I'm surprised you draw in Visio, I use it for block diagrams, with the cool "stretchy connector" lines which is what really set it apart. I'll have to look at the raw drawing stuff.
1 - 12 of 12 Posts
