This comes from wanting to make cosmetic changes, not from a need to increase performance, but it might. I read Richards thread about his Ruby mods, and Kevin Strong has a great article on his site. In both cases they took steps to lower the boiler, and I'd like to do the same. Ruby sort of reminds me of a woman in formal dress, holding her skirt tails up to tip-toe over a mud puddle! The main obstacle is the steam tube and where it enters the block. It looks like it would be possible to cut off and block the exiting inlet, then drill and tap the top of the fitting in the same way that the exhaust outlet is done and then fit it with an ell union. Then the burner could be carefully drilled next to the bolt that holds it in place, and the small lip on the boiler notched in the same place to allow the steam tube to run through the flue. This would allow the boiler to come down all the way to the reversing piston if so desired. I don't think the copper tube would be affected by the high heat of the burner, but I am concerned that oil could burn inside the steam tube and leave deposits that might eventually restrict or even clog the tube.
Has anyone tried this?
Can anyone think of a good reason not to?
I would be happy to hear any opinions
Kurt
Kurt
