Hi All-
After a year, my son and I FINALLY knuckled down and finished our Ruby kit. Set it up for inside admission and air tested it about a week ago as a bare chassis. Got it timed and everything ran great- got it down to about 5 lbs. of pressure and then let it just run for about a half hour to loosen up and break in.
Everything seemed nice and loose, so we mounted the boiler and finished it.
We did the first static fireups under steam and there are some weird things going on that I had a couple of questions about. I looked in the archives and couldn't find anything. So bear with me if this is old hat and you've read it all a million times.
1.) Lit the burner and the flame travelled back with no problem. Wasn't particularly noisy, but I noticed it only took about 1/16th of a turn on the burner knob to get it to the proper setting. Any more and the flame travelled out into the smokebox.
2.) Went through a tankful of butane before we got a full head of steam the first time. Re-filled and then waited for the pop off valve to indicate a full head of steam. Put the Johnson bar to run forward and cracked the throttle. It only hesitated for a moment and the cylinders cleared out and it ran fine.
3.) After the initial burst of power, the running gear settled down into a medium slow lope. Still smooth, but not remotely fast. It didn't matter how much I opened the throttle, the speed never picked up.
4.)Only got about 5 minutes of run time beore the fuel ran out. Went through three boilers full of water and could never extend the run time, although the fuel did marginally better- but only just. I didn't have to use a tank to get a head of steam the second time, but nearly did on the last one. Got maybe a minute after it built a head of steam.
Between the second and third running, I checked the couplers on the fuel lines to make sure they were tight and they were. Also checked the steam couplers and those were tight as well. So I'm puzzled. Should I have used a thread sealant on those?
What is the norm in terms of burner control and throttle control? Is it possible that the jet for the burner is too big? It seems like there should be more control on the burner knob than just barely cracking it to get the right amount of flame, and it seems like there should be more (any?) of a difference in speed when adjusting throttle.
Any ideas?
Dean
Any ideas?
Dean
