This thread relates to anyone with Accucraft Rubys equipped with balloon stacks still having problems with the burner flame going out when ever the smokebox door is totally closed. In our small group of Steamaholics, we have four Rubys, two with straight stacks and two with balloon stacks. Both the balloon stack equipped locos had been experiencing this burner flame-out problem. The burner appeared to be affected by back-pressure whenever the smoke box door was fully closed. In an attempt to correct the problem, I removed the balloon stack and drilled it out with a 5/16 inch drill using my small lathe. After trying the stack on the loco, without success, I drilled the stack out with a slightly larger (11/32 inch) drill. After again trying the stack on the loco, the burner problem was improved but not solved. I was a bit worried about thinning the stack tube too much, but decided to try one more time with a 3/8 inch drill. This time the burner worked fine with the smokebox door fully closed, and the stack did not appear to be weakened in any way. Now both of our Rubys equipped with balloon stacks have been drilled out to 3/8 inch diameter, and the burners work fine. This "fix" seems to have solved the problem.
emartin187, SA 360, Thunder Valley Narrow Gauge
