Hey guys,
Sorry for any mis-information on the build.
The main "frame" of the loco is the bottom section of the boiler and it is just 2 Aristo Pacific parts spliced together.
One was an older one, the other is a newer one that overlaps about 2 inches more than the other if you looked at a single
full piece. The front section is the older shell and it goes from the front of the loco to just where the weight ends towards the cab. The rear section is the newer piece and it goes forward from the rear of the cab to just shy of 2 inches into the weight area. The 2 sections are connected by what I call "splice tabs". These are the flat thin( bout .125 inch) black spacers that come with one of the Kadee couplers. There is one tab on the outside of the shell, one on the inside. I drilled a hole just large enough
to fit the screws that came with Kadee #830 couplers, 2 screws per tab. There is either 10 or 12 of these splice tabs on the
seam of the shell splice. and of course, it is glued as well. After the glue had dried, I cut off the excess screw on the inside with
the dremel using a cutting wheel. Worked great on the P-2, so I think I'll stick with this process. It does make for a STRONG
hold with little to no give to it.
Other than that, I've taken the weekend off from the loco due to our 5th year anniversary.
Spent most of today cleaning house, but most of the time with Deb. I'll be getting back to working on the loco sometime
next week. Maybe, just ,aybe, I might get a few minutes tomorrow or tomorrow night after the game.
No promises. But I think I will be cutting the vent holes in the top of the cab next and installing the hinges on the vent
doors. The boiler shell would be next to paint, then I can do the piping and electrical busses and cab interior.
Rocky
