I found this on a tank and military model forum. It should be real useful for those wanting perfect rivets, bolt heads, bead welding lines or non slip steel surface.
The produce is a water slide decal with thousands of tiny rivets, bolts, etc molded onto the decal material. You apply the decals before you paint. When painted over, you then have perfect rows of rivets, bolts or whatever.
Here is a link to an assortment sheet that gives you the spacing, sizes and shapes of the rivets on some of their other sheets.
http://www.archertransfers.com/AR88001.html
Scroll down to the bottom to see model showing a Tank component using the rivets on an HO flat car.
They make these for several scales and in different spacings. Scales include 1:16 and 1:32 but you can select a larger or smaller prototype rivet pattern to get what you need.
B0B
B0B
