I picked the 1N914 diode and the 78L type 6 volt regulator on purpose to make a point.
A rectifier is not a rectifier is not a rectifier......if they were all the same why do you think there are thousands of different types?
The 1N914 dide can comfortably handle 100ma of current, the 78L type voltage regulator is already maxed out at 100ma - so I went looking for a 5 or 6 volt relay with contacts that can handle 3 amps or better at 24 VDC.
Radio Shack didn't show any on their web site, so I looked at All Electronics, a surplus place. Of the 46 diferent relays they have listed, only one meets the requirements of 3 amp or better DPDT contacts and a 5 or 6 volt coil. This one:
http://www.allelectronics.com/make-a-store/item/RLY-642/6VDC-DPDT-RELAY-PC.-MT./-/1.html
Trouble is that the coil has a resistance of 50 ohms, so the relay will draw 120 ma when operating and you exceed the rating of both the diode and the 6 volt regulator that I listed.
You could try Mouser and Digi-key or active Electronics or Future Electronics or any number of others to try to find a relay with a higher coil resistance, but moving 3+ amp contacts takes a certain amount of energy and you are not going to find a low-current relay that will do that.
My point is simply that you can't just throw a bunch of components together in a circuit and hope that everything will work out in the end.
Maybe you know how to select each one and which component parameters are important and which one are not in a specific circuit, but I'm sure many people who might want to build this unit, cannot.
