1 - 11 of 11 Posts
Does anyone have know a method for removing solder. I used some brass pipe to make the boiler for a porter bash project. After soldering the smoke stake on it and then removing it has left a large gob of solder. Heating and scraping seems to just move it around. I'm thinking its going to come down to filing and grinding may be the only way.
Completely agree the braid is the best for model making.
Another method I have tried which works for some applications is to heat the solder and wipe it off with a wet sponge, it won’t remove it all but it’s a good starting point.
Solder suckers do have there purpose, I find them useful for electronics works.
Years ago as a technician with Honeywell, I always used the little desolder bulb. Never had any luck with the spring thingy. Now I'm definitely a desoldering braid man.
1 - 11 of 11 Posts
