Sal, I've actually gone the other direction, replaced orings with teflon tape. I think the teflon holds up better over the long run. But that's my opinion not based on empirical or scientific data as seems to be required on this website lately. Anywho, It might take a time or two to get the hang of wrapping it but I found after doing about 12 pistons using this method, that you wrap and pack until you can't possibly add any more, then place the piston in the cylinder rod end in first, through the gland until the teflon touches the cylinder. Then tap the piston with the wooden handle of a hammer. (That's straight out of the regner assembly manual.) It should cut a ring of the excess teflon, that's how you know it's seal all around.
