I would appreciate some input on an idea I've been thinking about for some time now. And especially from those who have experience with the train-li bender.
A lot of people just bend their rails by hand - I've done it in the past myself. You just have to add curvature at the ends of the rails with pliers. This is slightly cumbersome, but perfectly doable. (Some suggest sawing off the straight bit of each rail-end.)
Also, I've never tried hand-bending with ties mounted / two rails / at a time. I'm not sure it can be done.
I'm thinking of making a dual rail-bender, like the train-li, only all bending rollers will be fixed. Instead, both middle rollers will get "slip-on" diameter increasing rings, producing a specific radius track. My reasoning is, that achieving some approximate bend on the rail-ends is enough - the middle of the rail sections can be adjusted to exact radius by simple hand-bending. Also, bending both rails at the same time, with ties mounted, is a goal.
I figure beeing able to bend a few radiuses with corresponding diameter-change rings would do. Perhaps 4", 6" and 8" would do. One would use the 4" ring for curves between 4-6", the 6" for curves 6-8" and the 8" for 8-10" curves.
One thing that surprises me, is that the train-li bender has such long longitudinal distance between bending rollers. It would seem to me, that there is a relatively long minimum piece of track, that it can bend?
Also, I wonder if the train-li bender (or others?) possibly grip the "stem" rather than the "head" of the rails?
Making the cheapo-bender would be very simple. Drill six holes & bolt six ballraces & turn a few adaptor rings. Done. What do you think?
