I am laying my track out on the ground, trying to figure out the best route around trees, bushes, and structures. I tried this using RR-Track software but when I take it outside, it nowhere mimics my area. Most likely the result of poor surveying of the exact locations of objects and obstructions. When I lay the track out on the bumpy, soft dirt, it needs to be connected to get an accurate route set out. A problem emerged that creates some inaccuracies in this method: Each rail section, especially the curves, has a variable amount of rail sticking out each end with which to connect. If you push two curves together, there might be a gap in one rail or the whole connect occurs with one curve's rails pushed into the ties with no or minimum connect rail available. Each rail seems to be able to be pushed one way or another independently, resulting in different curves. I noticed that if I hold two brand new connected pieces of LGB R5 curves in my hands, curved downward, and push them together, I can make different diameters curves depending on which rail I apply pressure the most pressure. My question is, how do you know when you have the curves connected in their stated "15 foot diameter"? The same question comes up with long straight pieces as it seems that the rail ends are very moveable back and forth as are the tie locations. What should be their "resting locations"? When do you have to cut the rails to get the right exposed connection length? (Some of my track was purchased used so I worry that is has been altered but most of my concerns are with new track or when connecting an Aristocraft 10' diameter curve to an LGB 15' curve with all sorts of different exposed track end lengths.)
I need to be "standard" or "as advertised diameter" for planning as well as because the track will be placed on pre-formed Split Jaw PVC roadbed which will arrive soon and I just can't "wing it" with a railbender and adjust my roadbed after.
Any thoughts?
Jud
Any thoughts?
Jud
