Here's my theory on wiring; DCC install experts, tell me where I'm overlooking something...
1) Tap the power for the QSI board from the track inputs, allowing the track power to continue to the stock Bachmann board to power the smoke unit (via the switch) and the firebox lights.
2) Remove the LS/NMRA polarity switch, hooking the motor directly to the QSI board.
3) Run headlights, chuff switch, etc. off QSI board as illustrated in the instructions.
Now, to test this theory, I hooked everything up as such, without hooking up the chuff, speaker, or lights. Essentially, I'm just trying to run the motor. Using the MRC controller in what I'm assuming is factory default settings, my speed control is spotty at best. The motor spits and sputters at low speeds, finally picking up and smoothing out at around half throttle.
That doesn't seem right to me.
One would think "plug-and-play" would be a bit easier than this, so I'm certain I'm overlooking something somewhere.
Thoughts?
Later,
K
Thoughts?
Later,
K
