John
The short answer is no, that didn't come as a default functionality, but I'm sure that Shad is aware of the need and is working toward getting it reinstated.
Until that happens, the closest that I can give you is if you are in a topic and you find that you want to make a copy of all of the replies.
[*]Then use either the Add Reply button found at both the top and bottom of each topic page, or use the Reply link found in the header of each posted reply.
[*]After the Rich-text editor screen displays, on the left side in the grey area at the bottom you'll find a check box labeled Show Replies, click the check box so a check mark is displayed.
[*]Give the system time to refresh the editor screen, this will take more or less time depending on just how many replies there are in the topic.
[*]When completed, what you'll now find displayed at the bottom of the editor screen is a complete listing of all replies within the topic including their contents.
[*]This holds true across multi-page topics. The order they are listed in is most recent first to oldest last (i.e. reverse order).
[*]Then using using your mouse select (i.e. highlight) all, or that portion of the text in the replies that you wish to print.
[*]If you're using MS/Internet Explorer as your browser. [*]Click the File menu button in the browser's menu bar, [*]Then select and click the Print menu item. [*]After the print dialog displays click the radio button labeled Selection. [*]Make sure that you've got enough paper in the printer and then click the Print button at the bottom of the printer dialog. [/list] [/list]
The result won't be all that pretty, if you want to edit things to get the pretty the instead of printing right off the bat. If you have a word processing program then use the copy function {Ctrl+C} and the paste function {Ctrl+V} to copy the selected text into a blank document, do whatever editing you desire and print from there.
Hope the above is of help.
SteveC
