1 - 3 of 3 Posts
Hello,
Just picked up a used Playmobil G Scale Diesel Locomotive #4024 from an estate sale. Connected power to track but train will not move forward or backwards. It does however light up so power is getting through. Is there a way to troubleshoot this so I can get it to run? I don't see any switches in the cab or underneath that limits power just to lights.
Thanks in advance for your assistance.
Tony
Motor vehicle Construction set toy Vehicle Automotive tire Lego
Hood Motor vehicle Automotive tire Engineering Bumper
Since the light works, ths issue is either a bad motor or the wire/s to the motor do not have contact. Remove the motor block by inserting a flat wide blade screwdriver at either end of the block at the wide space (width of the motor block) and gently pry the motor block out.
1 - 3 of 3 Posts
