1 - 15 of 15 Posts
I've gotten tired of using butane grill lighters to fire my K28. One must work a safety tab and pull the trigger (tends to be awkward) and then the flame often blows out just as I stick it into the smokebox. Grumble!
Since some grills use piezoelectric ignitors, I searched Google and came up with this:
At its tip are two electrodes and, when I push the button, a very healthy spark jumps between them. Here's what the tip looks like:
It's easy to use. Stick the tip into the smokebox, crack the gas valve until you can just hear the gas flowing and push the button. I tried it out for the first time today and the loco lighted off on the first try. During the session, I shut the gas off a couple of times and then relighted the flame very easily.
Piezoelectric crystals have the happy characteristic of putting out a brief pulse of high voltage electricity when deformed. In ignitors, a spring-loaded hammer bashes the crystal when one pushes the button and the electrical pulse arcs across the electrodes at the tip. The manufacturer claims that it puts out a 10,000 volt pulse. At any rate, it does not require any batteries and it does not contain any fuel. So, it should last for a while.
I bought mine from Digitalfoto in Brooklyn. You can find several vendors by doing a Google search on "piezoelectric ignitors."
Llyn
Yes, I've seen those advertisements. Since I have, on occasion, had substantial tounges of flame come out through the smoke box door for an instant, I like to be able to stand well out of the line of fire when I tourch the engine off.
Llyn
My gas grill lighters all have piezo crystal igniters in the tip. I often find that, when I squeeze the trigger, the loco gas lights before the lighter!
Yes, Pete, I've noticed that too. However, with the one I've shown in this thread, you don't have to wrestle with the spring-loaded safety lever and the trigger to get it to fire. Guess it's mostly a matter of preference.
Llyn
Discussion Starter · #13 ·
The tip has an oval cross section which I measured to be 0.396" wide by 0.219" thick. The flexible section is 1/4" diameter.
Llyn
Ron Brown of Steam in the Garden magazine sellls a Piezoelectric igniter. There is usually an ad for it in each issue. I have been usuing one for some time time and it works great. Give Ron a try.
Don
1 - 15 of 15 Posts
