I'll be painting upwards of 800' of SVR SS code 250 track and read that using motor oil on the head before spraying with Rustoleum rattle cans and then wiping down with a rag after is the best to keep the connectivity good. It's also recommended to paint the rails before inserting the ties onto the rail but this leaves me with two questions.
How do you avoid connectivity issues when using clamps if the rails were all sprayed before?
How do you avoid connectivity issues if you cut track and the web is painted?
I wonder if maybe it's not a good ideal to spray the rail before it's all installed, or maybe avoid spraying near the ends of the rails and touching them up once the track is in?
Maybe I should build some painting jig to allow me to paint the track once it's all installed and working well that masks off the top of the rail head and ties below?
I'll also be using the SVR rail bender which I imagine could scratch painted rail if I use the bender after the rail is painted?
