I have an LGB Mikado which has an increadibly noisy gear train. I have tried grease, oil to reduce the grind but to no lasting effect.
I think I need to replace the gear component tems 100, 102 and 118 from the attached diagram to see if that soves the problem
http://www.gartenbahn.at/g_spur/downloads/downloadarchiv/lgb/eplosionsz/20872P-1.PDF
The question I have is where might I get the spare parts from? No luck with LGBoA - can any one suggest a source of these spares OR any alternative solution
Regards
PHIL
Regards
PHIL
