1 - 20 of 58 Posts
The Z3 ran in the Northwest servicing the areas around Couer d' Alenes lake in Idaho in the fifties. This area produced wealth in silver and gold exceeding the famed Comstock Lode of Nevada.
I love doing these standard gauge compounds. Although they can be tricky, when they are running correctly, they are a thing of beauty and awesome power.
The photo below shows the size of the low pressure cylinder on the Z3
60462
And here is the whole engine in operation
60463
The only drawing I was able to find is this from the NW Historical Society which doesn't show much detail so I will need to rely on photos for most of my detail. There were a couple of HO models of the engine and they are usually pretty good about detail but if they had to go by the same info I have there could some discrepancies.
I have the wheels on order and Dennis is cutting out the frame rails on the CNC mill. So I start with the cylinders.
A trip to the metal yard gets me started on the job.
60464
The cylinder is machined from square stock. The bores will be .750" and 1". The LP cylinder used slide valves so the valve ports are in the cylinder block Wood wedges are cut to hold the block at the right angle while the ports are drilled out. The drill bit shows the path the drill will take. Note the wide valve ports needed for the LP cylinder
60465
The LP cyl has a piston rod extension. I duplicate a non-functioning one and make a cylinder cover that covers the cylinder head.
60466
The HP cylinders had piston valves. I am using slide valves with a cross port plate. To duplicate the piston valve appearance, I first make my cylinder and valve covers from aluminum stock. The cylinder cover fits over the cylinder head which is 1" in diameter. I then cut a 1" hole in a .032" brass sheet with a step drill and spray it with layout dye. I place it over the head and scribe the outline.
60467
And on the band saw and 1" belt sander I trim it to fit and cut and shape on the belt sander Poplar strips which are taped on for fitting.
60468
Finally, a side cover is rivet embossed, annealed, and bent to shape and soldered on to the front sheet.
60469
60470
And here are the two engines as they will appear on the frames.
60471
Discussion Starter #3
Thanks
A little more time involved in the planning as there are no real plans available. The good news is that some of the parts are similar to the N&W Y6 which helped on the cylinders.
I have about 9 days so far in the actually machining and another week in drafting which I am still working on.
The tender for the Z-3 is the same design (class 22E) that was paired with most of the W-3 Mikados. I have those plans if you're interested.
Discussion Starter #5
Thanks Richard
The closest thing I found was this 35E which gives the general dimensions but not much more
60472
Also, I didn't get the drawing of the Z3 posted in the previous thread
Really looking forward to this build.
I was reading your previous threads again and i noticed that a lot of photo's are gone.
Especially your early builds that you posted: Quadruplex, Garratt, Uiutah 2-6-6-2 and the eerie triplex.
I wish i saved some of those pictures.
You are a big inspiration to me, keep up the good work please, dreams do come true for sure.
Thanks for sharing your mind blowing work, effort and time that you put in and to show details.
With best regards Igor from the Netherlands EU.
Discussion Starter #8
Thanks
many of the photos were lost when they converted to the new design
I use them myself to see how I did something back then. Now is is like reinventing the wheel
If you go to the informative threads index at the top of the forums, there are PDF copies of some of my builds. You need to scowl down a bit but I just looked and The Quad build is there with photos.
Discussion Starter #9
I got some real nice drawings from Richard
Bruce brought over some goodies yesterday A calendar from his welding shop in Idaho, an HO model of # 4023 and a spike from the railroad he found while hiking along the route.
60488
60489
I am machining the wheels today
60490
Discussion Starter #11
I was wondering when someone would notice it
I also like the name of his shop
@ Billy,
I have more questions than answers and i would like to follow up and walk in your shade(if possible! but hey: if you dont do anything, nothing will happen).
I hope it wont bother you that i am going to put some questions in now and then.
As stated earlier, i am going to follow this one with a lot of interested.
You let the wheels cast in cast iron, or is it a special alloy?
I was thinking to cast mine of a hardened aluminium alloy sinds i can cast up to 1400c/2550f, i should be able to do cast iron, but this would need some tricks and perhaps a extra oven.
The alu alloy i have in mind is the same alloy that they use for rims on car wheels and "sweeting/harding" it up with some copper zinc or just use plain zamac.
I think solid brass hardened with extra zinc will wear my (alu) rails very quick
Sorry that my technical English is not top notch.
Thanks in advance, with best regards Igor
Beautiful Build!
How do you cut your brass sheets?
I tried cutting 1/16 brass sheet on my scroll saw and it was just annoying and messy.
@ OldNoob.
I thought Billy used a band saw and a table saw to cut his own metals
You wont get away with a regular wood saw blade, not even a with very fine teeth.
You must have a saw blade with teeth that are special made to cut those kind of metals= non ferro metals, but dont cut lead or inox with it, both need different saw blades.
You can also try to adjust the speed, it is thin stuff, you pushing slower and the machine at max speed.
Option one
Clamp it between to thin sheets of wood, could also help against the up and down.
Option two
Or strap some wood to your fingers to push the piece down on the table half a inch to a quarter of an inch away from the blade.
I dont know your skills that is why i said two pieces of wood.( i can trim my nails with a mature table saw, but i am on a different level :cool:)
Option three
The hole in the table must be as tiny as possible, take a piece of wood and just run it over your table, to cut a line in it.
this piece of wood you can screw (from above) with help of two other pieces of wood to clamp it on the table, those two pieces will act with help of the screws as a c clamp.
This is all i can think about atm to assist you, hope this was of any help.
With best regards
  • Like
Reactions: OldNoob
Discussion Starter #16
Thanks for the questions
I don't cast my cast iron wheels. I get them from Walsall in GB. You can get them as bare castings or finished wheels. I get the castings, attach the counterweights with JB Weld, paint and quarter them. I will be posting something on that later.
On the Four Cylinder Heisler I did, we cast the wheels on Zamac 3 as the spoke design wasn't available. They came out pretty good but it was a lot of work.
60504
Cutting brass sheet isn't as hard as one would think.
Most of the sheet I use is .020" or thicker, This can be cut on a band saw or table saw. Any carbide tipped table saw blade will work but I use the attached blade as it gives a finer cut and can be used for mild steel also.
The throat plate on table saws has a wide slot to allow for tilting the blade. I made an insert out of MDF and then raised the running blade to make a zero clearance slot. This prevents the sheet from bending down during the cut. On very thin sheet, I sometimes lay it on top of a piece of plywood and cut through both at the same time. I use the band saw for curved cuts.
Here is my old crosscut sled which has been replaced with an aluminum one and the zero clearance throat
60505
60506
Discussion Starter #17
The rough castings require several machining steps. Here are the wheels during the machining process. The wheels in the front have the tread roughed in and still need the hub turned and the final tread plunge cut. The ones in the rear have only the face done and are in the process of receiving the tread cuts.
60511
The tread then gets its final cut, counterweights are CNC cut and JB'ed on and they receive a coat of low sheen paint.
Here you can see the three different counterweight sizes
60512
The pilot has an interesting bracket with vertical slots to, I assume, allows it to be raised or lowered somewhat.
I cut the slots on the mill with a 1/16" end mill. I don't have any drewings of it so I just eyeball it and scribe the vertical lines with my calipers and freehand scribe the curves. I then cut it out on the 1/8" band saw blade and finish up with the 1" belt sander
60513
The headlight is made by boring out a piece of 3/4" round to 5/8". A concave is made in a 5/8" aluminum bar with a drill bit in the lathe. it is smoother out with 600 and up to 2000 and finally polished with SemiChrome. The glazing is 1/16" polycarbonate and the bezel is turned from 7/8" aluminum stock.
60514
It is hard to tell from this photo but to make the curvature of the number boards, I did something new to me. I usually use a fly cutter to cut large radii or an end mill for small ones but here one was too big and the other too small. In the past, I would use the drum sander which got it close but not perfect. It finally dawned on my that as my end mills only go up to 1/2", why not use a router bit. So here is a 3/4" carbide tipped router bit doing the job nicely
60515
So here is the front deck to date. I haven't explained everything here so, please ask any questions you like
60516
60517
Looks great so far, Bill! One relatively minor nitpick though, NP had a pretty distinctive style of headlight with a lighted forward-facing number board on top, with the top tapering down to the rear of the headlight body. They used this style on all of their road locomotives in the electric headlight era. Here's a close-up of the headlight on NP 328 as an example...
60518
Discussion Starter #19
Thank you
I don't know how I missed that but it was there
1 - 20 of 58 Posts
