So, there they are....
I am disappointed in the instruction booklet. its instructions are I think better suited for someone who has run/owned live steamers before.
I understand that I am to add the fuel, then oil, then water. BUT they lack a diagram labeling all the different items on the engine and tender.
for example, they make no mention as to WHERE to add the oil. in which holding tube do you add that?
I understand that you add the water to the tender, that its a warm bath for the fuel, but that is NOT where the water for boiling goes, correct? although in pic 9 and 10, there appears to be a connection for a water source tube. Am I right here?
I believe I will add the water to the boiler in the valve in pic 7
the documentation fails to fully explain the two plastic control knobs and EXACTLY what they do. I have an idea, but it would be so nice to have confirmation from documentation.
So, for now, I will sit on my hands, look around for butane fuel, anyone want to let me know where they get theirs? and hope that someone from the NHGRS wants to lend a hand to a newbie.
And, yes that middle driver is blind, I was a bit disappointed, but after thinking about it, I am fine with it.
I tested it out on the floor with some spare track, it will negotiate a 5' DIA curve as advertised. BUT, its not happy with it. not because of the wheel arrangement....but because of detail parts on the back of the cab hitting the tender. The hand rails on the back of the cab, will actually hit the tender as it goes around the curve. I was really surprised, even at the second drawbar hole.
Now, with the cab roof removed, the engine WILL navigate a 4' DIA curve. with the cab roof, the corners strike the vertical side plates on the tender, the ones seen in pic 8. I have in my mind the plans to cut these side plates off to some degree as I see no real use for them. they might be there because the proto has them, but they make it very difficult to get the fingers in there if the cab roof is on. plus if i cut them back I can use all my 4 sidings in the layout, this will be really nice seeing one is perfect for setup and cooldown.
Kevin
