1 - 10 of 10 Posts
I have an MRC Control Master 20 with Aristo Elite Power Supply and was given an older Aristo TE (27hz). Not having laid track yet I have not tried either of these remote control systems. Does anyone have experience with them and an opinion either way? Will be running a couple of low end Aristo steam engines with track power and no more than three or four cars.
Thanks.
Keep in mind that apparently there have been at least two generations of MRC CM20's as well. I have what is apparently an older one that will barely suffice to run an LGB starter set with an added caboose and all with lights. It will overheat and shut down after a while.
Beyond that I have no experience with the newer MRC CM20 or the Aristo TE of any generation or frequency.
Easy!
1. There are 4 screws in the bottom of the receiver. Take the receiver apart and set the plastic case aside. Now you can mount it in any train car. I like to put them in tenders just 'cause I'm a steam nut.
2. There's a big red & black wire. Connect your battery there. I use NIMH batteries from all-battery.com and their $25 charger.
3. Now wire the "track" terminals to your loco.
Posted By wchasr on 06/12/2008 5:27 AM
Keep in mind that apparently there have been at least two generations of MRC CM20's as well. I have what is apparently an older one that will barely suffice to run an LGB starter set with an added caboose and all with lights. It will overheat and **** down after a while.
The one I have is one of the first production units.
1 - 10 of 10 Posts
