1 - 4 of 4 Posts
I have a USA 20 ton Switcher engine, has only 1 motor block, I am trying to isolate the 2 motor wires that run the motor, there are 4 coming out of the block that goes to the wiring board, 2 come out and are joined up with a tamyia connector from 2 other ones that are from track pickup points, and they go to the board that are marked - and +.
2 more go directly to the board and are marked M- and M+ , wich one is the one that runs the motor? Trying to isolate them to convert to battery power, didnt know which forum to put it in.
Tom h
M+ and M- are indeed the motor leads.
It sounds like you are installing a decoder.
I would STRONGLY recommend you go to radio shack, and buy an inexpensive voltmeter and use the resistance function (ohms) to be able to test that the pickup leads are INDEED isolated from everythig else except the right and left wheels.
1 - 4 of 4 Posts
