1 - 8 of 8 Posts
It's all Mr Walas's fault
Some times when I see something a switch goes off in my head and the way on how to make something comes very quickly to me.
When I saw the new LGB Kof I thought that was really cool, then Chris posted his way cool "low slung" Porter and then I really wanted something "low slung" like that but in Dismal form, and began considering how to use a Mack to do it
One day sketching in my little notebook the switch went of, Aha!, so I decided to make something like the Kof with influences by Plymouth
What I started with:
Introduce Mr Razorsaw
Relocate the modified cab back and cut it into the frame, added some additional frame extenstions
Cut the radiator off the hood, add a new styrene hood
New bits added,
New interior started
Underside showing self adhesive lead weights stuck where-ever I could fit them
Be carefull to make sure the engine weights are balance evenly, helps performance
Painted Borracho's mining road colors Silver and Black (sorry Chris)
Still needs a little weathering and a dullcoat to even out the paint, but its all ready for service on the line.
Thanks guys, even I'm a bit surprised at how well this one came out, considering I used as many stock parts as I could putting it together. I really should also give a shout out to Dave Fletchers Masterclass's. Its amazing how much can be done with styrene and other bits once you seen the alchemy explained the way the Masterclasses do.
Dan, I get lots of sleep, I was just lucky recently to have some rare free-time at the workbench, guess I had a lot of model energy pent up when I started.
Richard, yes, I found by carefully cutting the Mack hood portion away from the radiator, then inserting either a wire screen or some other textured surface, I think this used corregated roofing or metal floor deck styrene, builds a convincing radiator, and I get 2 per Mack so I have a few always laying around.
1 - 8 of 8 Posts
