Is anyone familiar with the Bernzomatic Micro Torch? I picked one up at Home Depot the other day. It uses butane as a fuel. The back end of the
torch has a place to fill it with the butane. The butane comes in a canister about an inch and a half in diameter and about six inches in length.
The instructions tell you to hold the canister of butane upside down while aligning the small plastic nozzle with the small metal receptacle of the
torch. First off, the nozzle of the butane canister only presses up against the torch receptacle, it doesn't actually fit over it. Then they tell
you to use a pumpnig motion to get the fuel into the torch. The butane is under pressure, so why the pumping? I tried several times to get fuel into
the torch. Each tiome more fuel got onto and froze my hand that was holding the torch than into the torch. I did manage with difficulty to light the
torch. Not a very impressive flame. Yes, I know it's a micro torch. The flame that I did get would sputter out rather quickly. I think, on my next
trip to Home Depot, the Bernzomatic torch will accompany me to the return desk.
Has anyone had any experiences with these torches, or the laerger one the seems to actully hold the entire canister of butane.
