Hi Tim, Glad to hear you are getting started on you Connie. I look forward to seeing your build log. I used 1/32 electronic rosin core solder with some rosin paste on both parts. I used a small butane to heat the joint, that way you can heat quickly and get off before things get too hot. Some of the later pieces I tinned both parts and then clamped them together with spring clamps and reheated the joint. That seemed to work best. I did have a couple of disasters where parts melted. You will notice on some upcoming posts that some of the links on one side are modified originals, on the other side they are scratch made. Some parts are scratch made on both sides as it just seemed easier than trying to modify something.
My Connie is coming along slowly with numerous interruptions, however I will be posting some progress in the next couple of days. The valve gear is almost done. The cylinder and pilot mods are in progress.
