1 - 10 of 10 Posts
Got a bman 2 6 6 2,without instructions,what are the wires in the coal bunker for? Assume tender wiring or battery trailing car,does someone tell me the wiring code ,thanks!
Discussion Starter #3
Thanks Greg! Wire code and "customer use" but doesn't say what is which and for what?
So you have those 4 wires? I wonder if they are just unterminated at both ends? If so my guess would be for connecting functions or a different sound unit.
So, these 4 wires are loose in the bunker? Can you find these same 4 wires somewhere in the boiler?
Discussion Starter #6
just some wires in the bunker apparently attached to the PNPlay board (underneath) can't see where without taking things apart!
did you peek inside the boiler? Anyway, I think it's either 4 wires threaded from one end to the other, or they are connected to some of the "extra" pins in the socket.
To me it looks like wires going from front to rear so one could hook up a motorized smoke unit to a decoder and not have to run your own wires..
Discussion Starter #10
4 wires with loose ends ,disassembled the 2 6 6 2 t ,added 5 more wires to install a sound unit and trailing battery car connection,eyeballed with a butcher's view the incense generator,will replace that eco puffer with 2 usa trains smoke units and a chuffed timed blower!
1 - 10 of 10 Posts
