Just got an incredible deal on a new house and proceeded on designing a track for my backyard, I opted for a nicer newer house instead of having a big backyard (first house
), so I will deal with my size constraints.
The bottom of the boundary in this XTrkCad file is the house and the other side is this giant hedge I cant go by so those our my boundries.
I designed a 2 run layout, maximum radius I can muster is 13' Diameter, the inner track is 11.75' Diameter, I set it up as a dog bone layout with a raisable section in the middle for the lawnmower (and access).
I didn't add any switches or plans for a steamup bay, Ill leave that up to you all for some ideas on how to design one properly, yes its squished, something to run my own trains until I get the big club
track built at tradewinds park (so when I can afford my bigger engines, slow running on my track, stretch legs at the club track
I planning on building this around Jan (after diamondhead of course) - February (too busy in mountains of boxes right now lol), it will be a raised track. All track is seperated by 7.5" from center to center.
0 degree grade, built like my other tracks.
http://www.mylargescale.com/Community/Forums/tabid/56/forumid/11/tpage/1/view/topic/postid/238/Default.aspx#238
(right click, view image to see the full size (might have to zoom in with the magnifying glass))
1. blocked by bushes, I mean you cant walk through, track goes over bushes
2. Tree might be removed, relocated is what I meant lol (its small, bush size)
3. Door brick, is my screen patio door with brick in front on the lawn side.
Thanks for your help (and its fun to design tracks anyway )
Files
PDF:
http://www.livesteamers.org/Backyard-1st-draft.pdf
http://www.livesteamers.org/backyard-railroad-1stdraft.xtc
XTrkCad File:
(if your dont have XTrkCad to edit get it here , learning curve is not bad, plus its open source (free))
Files
PDF:
XTrkCad File:
