FWIW:
Charge/discharge protection circuits or monitors are used by some and most definitely not all original equipment manufacturers or aftermarket pack builders/assemblers. Please consider that those that believe such is true of ALL Lithium-Ion cells or any Lithium cells for that matter may become complacent with the care and feeding of their Lithium batteries. Reckless behavior with this technology has long been its Achilles heel; miss information fosters bad habits IMO. Remember that the aforementioned protection circuits are ancillary devices or accessories not integral parts of the individual cells, accordingly you can include same or not.
As eluded to by others the concept that outside forces contribute to self or shelf discharge is true of the aforementioned protection circuits as a slight quiescent current draw is continuously drawing down the battery.
Best case for Lithium cell storage is in the discharged state for extended periods of time while frequent charging is purported to be desirable if in play. Regular deep discharge ultimately is the cause and effect of cell capacity reduction. In other words Lithium reaps benefits from frequent charge cycles regardless of the batteries discharge state.
Occasional testing of your batteries is paramount IMO, especially if your cells are stacked in series/parallel configuration. A dropped cell is realized by decreased discharge current, capacity reduction and reduced voltage under load. I have found many bad cells by using a loaded expanded scale volt meter, (no load voltage is a go, while a loaded voltage test depicts another reality). More sophisticated purpose built Lithium battery packs typically come with an additional pigtail attached with a plug which interfaces with a charger that can monitor, balance and charge each cell individually. The increased life of these batteries is nearly doubled when used in high discharge environments. Its easy enough to check a batteries individual cells with a voltmeter to identify a bad cell too.
Regards,
Michael Glavin
Regards,
Michael Glavin
